FeatureLayer Mouse over cursor
3121
06-04-2012 06:26 AM
bayramüçüncü
I have a featurelayers in mymap. How can I change my mouse cursor over the layer? Default cursor is Arrow. If I get over a layer, cursor should be Handle.
DominiqueBroux
Esri Frequent Contributor
As Joe suggested, you can change the cursor when hovering a feature by wiring up the MouseEnter and MouseLeave FeatureLayer events.
You can change the cursor with code like:
private void FeatureLayer_MouseEnter(object sender, GraphicMouseEventArgs e) {   MyMap.Cursor = Cursors.Hand; } private void FeatureLayer_MouseLeave(object sender, GraphicMouseEventArgs e) {   MyMap.Cursor = Cursors.Arrow; }
JoeHershman
Map has a Cursor property, FeatureLayer has MouseEnter, MouseLeave events.
-Joe
bayramüçüncü
Yes it has properties but not change mouse cursor. Some controls has cursor property, but featurelayer has not cursor property. So I cannot apply this.
DominiqueBroux
JoeHershman
On you map add a MouseMove event handler.
private void MapMouseMove(object sender, MouseEventArgs mouseEventArgs)
    MapPoint mapPoint = MyMap.ScreenToMap(mouseEventArgs.GetPosition(MyMap));
    MyMap.Cursor = MyFeatureLayer.FullExtent.Intersects(mapPoint) ? Cursors.Hand : Cursors.Arrow;
Will change the Cursor anytime it is inside the extent of the FeatureLayer
-Joe
