FeatureDataGrid Hover
982
07-09-2012 01:29 PM
ChristineZeller
I'm using the example http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#FeatureDataGrid
Basically I love the fact if you hover over a feature on the map (in the example it is counties so if you hover over San Diego) the record in the table becomes slightly highlighted.  Unfortunately if the record is not in view the table does not auto adjust to place it in view.  I was wondering if there was a way to do this (similar to when you select a county but just do it for hover).
Christine
PreetiMaske
Actually you can do it. I haven't tested it but should work.
Subscribe to MouseEnter="FeatureLayer_MouseEnter"
private void FeatureLayer_MouseEnter(object sender, GraphicMouseEventArgs e)
      MyDataGrid.ScrollIntoView(e.Graphic,null);
PreetiMaske
