FeatureDataGrid Date
1190
05-05-2011 11:53 AM
DarellStoick
I have a SQL dateTable with a field called
LOG_TIMESTAMP SQL DataType is -datetime
This table is used as a the source for an XY Event layer in an mxd.
The mxd is the source of a service in ArcGIS Server Manager.
In a simple Silverlight app based on http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureDataGrid
Create a Feature Layer
<esri:FeatureLayer ID="LayerName" Url="http://.../0" FeatureSymbol="{StaticResource SelectSymbol}">
                        <esri:FeatureLayer.OutFields>
                            <sys:String>*</sys:String>
                        </esri:FeatureLayer.OutFields>
                    </esri:FeatureLayer>
Create a FeatureDataGrid
 <esri:FeatureDataGrid x:Name="MyDataGrid"
                                  Margin="1"
                                  LoadingRow="MyDataGrid_LoadinRow"
                                  GraphicsLayer="{Binding Path=Layers[LayerName], ElementName=MyMap}"
                                  Map="{Binding ElementName=MyMap}" Width="398" Height="121">
            </esri:FeatureDataGrid>
In MyDataGrid_LoadinRow
Dim myValue = e.Row.DataContext
If I test myValue I get
?myValue.[GetType]().GetProperty("LOG_TIMESTAMP").GetValue(myValue, Nothing)
#5/2/2011 1:34:06 PM# {Date}
    Date: #5/2/2011 1:34:06 PM#
In the grid I only get 5/2/2011 and no time?
The ESRI Type seems right on the rest endpoint
LOG_TIMESTAMP (Type: esriFieldTypeDate, Alias: LOG_TIMESTAMP, Length: 16 )
Any Ideas on why I'm only getting the Date part of the System.DateTime
SDK 2.1
ArcServer 10 sp1
ChristopherHill
We are aware of this issue and are looking into a solution. Only date is being displayed and the editing control is a datepicker which only changes the date portion of the DateTime. The Time portion is there its just not being displayed in the FeatureDataGrid. you can modify the datetime stored in the garphic attributes, but the FeatureDataGrid by default modifies the date.
DanMcCoy
Chris,
Is there a bug # associated with this issue?
Dan
