FeatureDataGrid - DataGridRow
994
07-06-2010 02:00 PM
bbieb
I believe this is simple but am having trouble trying to find a solution.  If you have a selected graphic in a feature data grid, how can you retrieve the DataGridRow associated with that graphic??
Thanks.
brian
brian
bbieb
Dominique or Morten?
brian
AliMirzabeigi
Hello Brian,
You can use SelectedItems property of FeatureDataGrid to get selected rows collection. Here is a code snippet that shows how to retrieve value of a cell in the first selected row:
IList selectedItems = MyFeatureDataGrid.SelectedItems;
object value = selectedItems[0].GetType().GetProperty("YourPropertyName").GetValue(selectedItems[0], null);
Thank you,
Ali
bbieb
Hi Ali,
Thanks for the response.
Still having troubles....
For Each g As Object In selectionDataGrid.SelectedItems
     g = g  'g = nothing
What I want to do is the following.
' there was a change done to the selected graphics
' I want to show the user that the change was completed by changing
' the row color and de-selecting the graphic
For Each g As Graphic In selectionDataGrid.SelectedGraphics
    Dim row As DataGridRow ' = get datagrid row for g
    row.Background = New SolidColorBrush(System.Windows.Media.Colors.Yellow)
For Each g In selectionDataGrid.GraphicsLayer.Graphics
     If g.Selected = True Then
          g.UnSelect()
     End If
I am using Silverlight API v1.2
Thanks.
brian
brian
