FeatureDataGrid Columns
1018
06-02-2010 08:30 AM
ChrisYeager
Is there a way to specify what columns are visible within the FeatureDataGrid?
Thanks!
dotMorten_esri
Esri Notable Contributor
The simplest way to do that is limit the outfields you request from the server
ChrisYeager
Thank You that did the job!
ChrisYeager
Now im trying to display maptips on the selection of an item on the FeatureDataGrid.  I already have maptips working on my featurelayer but it would be ideal to have them pop up when i select them from the FeatureDataGrid.    Any ideas?
dotMorten_esri
MapTips can only be triggered by MouseOver. If you need this behavior, pop up a control next to the feature on top of the map when you interact with the datagrid.
