FeatureDataGrid AutoChangeMapExtentCheckBox
830
03-16-2012 10:18 AM
ScottSteigerwald
I'm trying to make it so that the AutoChangeMapExtentCheckBox property is checked by default.  In the past, I have been able to do this by creating a copy of the template and setting the checked property of the AutoChangeMapExtentCheckBox to true.
With the latest version of the API, it seems I can't create a copy of the template anymore?  Has the functionality to create a copy of the template for a featuredatagrid been removed, or is there something wrong with my project?  If we cannot create copies of the template anymore, how can we set AutoChangeMapExtentCheckBox?
[ATTACH=CONFIG]12784[/ATTACH]
JenniferNery
What version of the API are you using? If you are using v3.0, you need to use Expression Blend Silverlight 5 Preview.
