Feature layer service doesn't show feature symbol as dotted line correctly
1231
04-08-2011 06:08 AM
XiujuZhou
I created a Feature Layer service and test it on ArcGIS My Map. I found out the feature symbol is not correct. It is dotted line symbol in MXD file and shows correctly in ArcCatalog. But it shows solid line wrongly when test it on the rest service URL in Internet Browser. Please help!
JenniferNery
Thank you for sharing this to us. We are aware of this bug. The fix was included in v2.2 beta.
XiujuZhou
Thanks you. Jennifer. Is v2.2 beta good for my production version of application? I like to use it if it is good.
XiujuZhou
I cannot use 2.2 Beta version since I was told so. so is there anyway trick like around to avoid this problem in version 2?
JenniferNery
If you need the dotted border outline, you cannot use the symbol defined by your service. You would have to create your own symbol template and use this instead.
