Feature layer not displayed/available
1022
09-20-2010 11:07 AM
DuaneAnderson
When I use one of the arcgisonline tiled services, I am able to see (hover over and retrieve) my feature layer(s).  When I change the url to one of my own tiled services, the feature layer(s) appear in the layer list, but are not displayed/available to hover over.  The only thing changed is the service url value.
AliMirzabeigi
Have you verified whether the spatial references in your map and the feature layer match?
DuaneAnderson
Ali:  I have reviewed all spatial references and they match exactly.  When I use an arcgisonline tiled service, which is a DIFFERENT spatial reference, my feature layer works fine.  Thanks for responding and I look forward to any advice you can give.  Duane.
DuaneAnderson
Ali:  I use a locally defined projection file, WCCS (Washington County Coordinate System), for ALL of my services while your online services use a numeric id, e.g. ESRI_StreetMap_World_2D uses Spatial Reference 4326.  Don't know if this helps, but thought I'd throw it in to the conversation.  Thanks, Duane.
