Editing Guid fields
2735
09-21-2010 09:56 AM
WilliamKimrey
Hello all,
I'm hoping that I'm just doing this wrong, but I can't seem to change a GUID field's value with a FeatureDataGrid.  I think this is the way to do it:
FeatureDataGrid.BeginEdit();
FeatureDataGrid.SelectedGraphics[0].Attributes["NAME_GUID"] = newGUID;
FeatureDataGrid.CommitEdit();
If I check the attribute before and after this code is executed the GUIDs are different.  However, this change does not persist.
So, am I just doing this wrong, or is there a problem with editing GUIDs?
Will
AliMirzabeigi
Like the ObjectID fields GUID (GlobalID) fields are automatically assigned by the server and cannot be modified by users.
WilliamKimrey
Thanks for the heads up.  Just to clarify, I can't edit ANY Guid field?  Or can i just not edit GlobalID fields.  I don't have GlobalIDs for this featureclass so I just want to make sure that it's a limitation on the GUID type rather than specific field names.
AliMirzabeigi
GUID fields are identified as type of esriFieldTypeGlobalID (this is what I meant by GlobalID fields in my previous post) and they cannot be edited (assigned by the server) regardless of their field names.
WilliamKimrey
Ok, thanks for the clarification.  Guess I'll have to figure out something else.
