Feature Grid from Version 2.2 API issue
915
08-26-2011 01:02 AM
ManojrajTeli
I am facing weird problem as the Featuredata Grid Having rows and columns Returning Null value for Itemsource because of this i cant export the feature data grid to excel.
JenniferNery
Did the earlier version have the same behavior? Can you share with us some code or steps to replicate the issue? Thanks.
ManojrajTeli
No i used 2.1 version in that it was not giving Problem for Item Source and it was returning all values and exporting the Data as desired but i shifted to 2.2 version and it started giving problem.
Here is the code.(source = (grid.ItemsSource as System.Collections.IList);)
[HTML]
public string ExportDataGrid(bool withHeaders, DataGrid grid)
            string colPath;
            System.Reflection.PropertyInfo propInfo;
            System.Windows.Data.Binding binding;
            System.Text.StringBuilder strBuilder = new System.Text.StringBuilder();
            IList source;
            if (grid.SelectedItems.Count > 0)
                source = (grid.SelectedItems as System.Collections.IList);
            else
                source = (grid.ItemsSource as System.Collections.IList);  //Giving error
            if (source == null)
                return "";
            List<string> headers = new List<string>();
            foreach (DataGridBoundColumn col in grid.Columns)
                if (col is DataGridBoundColumn)
                    headers.Add(FormatCSVField(col.Header.ToString()));
            strBuilder
            .Append(String.Join(",", headers.ToArray()))
            .Append("\r\n");
            foreach (Object data in source)
                List<string> csvRow = new List<string>();
                foreach (DataGridColumn col in grid.Columns)
                        binding = (col as DataGridBoundColumn).Binding;
                        colPath = binding.Path.Path;
                        propInfo = data.GetType().GetProperty(colPath);
                        if (propInfo != null)
                            csvRow.Add(FormatCSVField(propInfo.GetValue(data, null).ToString()));
                strBuilder
                    .Append(String.Join(",", csvRow.ToArray()))
                    .Append("\r\n");
            return strBuilder.ToString();
private void BuildStringOfRow(StringBuilder strBuilder, List<string> values, string strFormat)
            switch (strFormat)
                case "XML":
                    strBuilder.AppendLine("<Row>");
                    strBuilder.AppendLine(String.Join("\r\n", values.ToArray()));
                    strBuilder.AppendLine("</Row>");
                    break;
                case "CSV":
                    strBuilder.AppendLine(String.Join(",", values.ToArray()));
                    break;
        private static string FormatField(string data, string format)
            switch (format)
                case "XML":
                    return String.Format("<Cell><Data ss:Type=\"String\">{0}</Data></Cell>", data);
                case "CSV":
                    return String.Format("\"{0}\"", data.Replace("\"", "\"\"\"").Replace("\n", "").Replace("\r", ""));
            return data;
[/HTML]
