failed to display lable of feature layer
5070
6
10-26-2010 12:21 PM
XiujuZhou
I have feature layer created by feature service. , the lables of layer are displayed In the mxd file. but not show on silverlight application as feature layer and only show as ArcGISDynamicMapServiceLayer. why? how to fix it?
JenniferNery
I'm not sure I understand the question.  What label are you talking about and where do you expect this to show on the FeatureLayer?
Can you explain using sampleserver? This is a FeatureService that can be used for FeatureLayer (http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/LandusePlanning/F...) This is the corresponding MapService that can be used in ArcGISDynamicMapServiceLayer (http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/LandusePlanning/M...)
STharshini
Please check the following link.This is a plugin issue
http://forums.arcgis.com/threads/10273-autolabels-not-appearing-in-flexview?highlight=label
XiujuZhou
Thank you Jeniffer. please compare map service and feature service for the same mxd file you will know what I mean. the feature is polygon with red fill symbol. feature service has no label shown while mapservice does.
http://mapserver2.pwe.pserv.coh.gov/ArcGIS/rest/services/API2_3dpc/MapServer
http://mapserver2.pwe.pserv.coh.gov/ArcGIS/rest/services/API2_3dpc/FeatureServer/2
JenniferNery
I don't have access to the links you provided.
XiujuZhou
Jennifer, I set properties of the Layer as " Label Feature on This Layer" in mxd file, and labels show on map in the mxd. then I created map service and feature service. but labels display on the map service not the feature service. below is part of information of feature service copied online:
Drawing Info:
Renderer:
Simple Renderer:
Symbol:
Simple Fill Symbol:
Style: esriSFSSolid, Color: [230, 0, 0, 255]
Outline:
Simple Line Symbol:
Style: esriSLSSolid, Color: [255, 255, 255, 255], Width: 1
Label:
Description:
Transparency: 0
Labeling Info:
Label Placement: esriServerPolygonPlacementAlwaysHorizontal
Label Expression: [DPC_ID]
Use Coded Values: True
Symbol:
Simple Text Symbol:
Type: esriTS
Color:255, 255, 255, 255
Background Color: null
Border Line Color: null
Vertical Alignment: bottom
Horizontal Alignment: center
Right To Left: False
Angle: 0
XOffset: 0
YOffset: 0
Font Family: Arial
Font Size: 8
Font Style: normal
Font Weight: normal
Font Decoration: none
Min. Scale: 0
Max. Scale: 0
JenniferNery
Okay, that makes sense to me now.  This feature is not currently supported.  Please refer to this related thread: http://forums.arcgis.com/threads/2339-Labelling
