export layer as shapefile
1598
12-20-2012 09:55 PM
TamarMakatsaria
hi,
I'm struggling with the following problem:
I'm writing a web-application in Silverlight where client chooses a basemap and then adds some graphic layers on it(creates new layers).
Thus, the client creates a custom map.
What I want to do is that I want to save/export this custom map so that I could open it in ArcGIS and use the layers of it.
Is there any options to export the map layer as a shapefile or export the whole map as .mxd so it can be opened in Arcmap?
Thanks in advance,
Tamar
DominiqueBroux
Esri Frequent Contributor
There is nothing at client side allowing to export a graphicslayer to a shapefile.
Nevertheless you should be able to do it at server side by using a geoprocessing tool.
This thread might help.
TamarMakatsaria
Thank you very much, Dominique,
I will probably use Extract Data Task tool and make a geoprocessing service.
