ESRI Standard Map Template
2758
12
07-06-2010 08:26 AM
TonyAlmeida
MVP Regular Contributor
I have installed Visual Web Developer Express 2010 Microsoft Expression Blend Software Development Kit (SDK) for Silverlight 4 and Microsoft Silverlight Toolkit Silverlight 4 i can't seem to see the ESRI Standard Map Template in Visual Web Developer Express 2010. Any suggestions?
TonyAlmeida
Can some one share the template with me? I am using Visual Web Developer Express 2010.
Thanks.
dotMorten_esri
Esri Notable Contributor
What language version of Windows are you using?
TonyAlmeida
i am using  windows xp english
dotMorten_esri
Did you install the Blend SDK prior to installing the Silverlight API?
http://www.microsoft.com/downloads/details.aspx?familyid=D197F51A-DE07-4EDF-9CBA-1F1B4A22110D&displa...
Did you see a template option in the installer wizard?
TonyAlmeida
I believe i installed Silverlight before blend. I guess i didn't pay attention to the template option. I will uninstall and re install everything. In which order should I install?
dotMorten_esri
Visual Studio 2010 and Blend SDK should be installed prior to the ArcGIS Silverlight API.
TonyAlmeida
which one has the template option that i should pay attention too?
egismazeika
that is "ArcGIS Silverlight API" 🙂
TonyAlmeida
I have reinstalled everything (Visual studio Express 2010 Microsoft Expression Blend Software Development Kit (SDK) for Silverlight 4 and Microsoft Silverlight Toolkit Silverlight 4) and know i only get the VB templates no C#... when i install ArcGIS Silverlight API i don't get the option to view the templates.
