ESRI Silverlight Templates Missing
3678
09-10-2010 02:55 PM
GregoryDillon
When developing in VS 2008 and 1.3 we used to see several ESRI templates (ESRI Standard Map Application and ESRI Showcase Map Application) when we selected File>New Project.    I don't see these options when using VS 2010 and 2.0 (see attachment).   Are they missing (or non-existant)?   Did we miss something in the install?
Thanks.
by Anonymous User
Not applicable
Try to install Expression Blend 4.
dotMorten_esri
Esri Notable Contributor
As a minimum you need the Expression Blend 4 SDK (or the full Expression Blend install) prior to installing the Silverlight API Setup to get the templates.
GregoryDillon
Installing the Expression Blend for Silverlight 4 SDK and then uninstalling and installing the 2.0 fixed this issue (the modify and repair option don't fix the template issue - you much uninstall/install the API instead).
Its funny both me and my co-worker thought we installed the Expression Blend for Silverlight 4 SDK.   Oh well.
ZachEdwards
Thanks Greg, this definitely worked!
