ESRI.ArcGIS.Samples.PieChartSymbology  for arcgis silverlight api 2.0
2782
01-17-2011 02:12 AM
rohandontireddy
hi im using ESRI.ArcGIS.Samples.PieChartSymbology version 1 in arcgis 9.3.1 version for demographics
my problem is now i migrated the code to 10 version.it is giving error as stylepalette not found
as there are changes in silverlight 4 datavisulation toolkit and arcgis 10 syntax.
Is there any upgraded code available for this
JenniferNery
Did you download from http://help.arcgis.com/en/webapi/silverlight/gallery.html? Search for "Pie Chart Symbols"
rohandontireddy
"I downloaded the code from that link only but now that code is not working for arcgis 10 because of changes in silverlight 4 changes"
DominiqueBroux
Esri Frequent Contributor
When did you download the code?
The sample has been updated January, the 21st here : http://www.arcgis.com/home/item.html?id=b135d66549364786b381e85451742d56
It's now working with SL4, the latest toolkit and ArcGIS SL 2.1.
You can also get the code in this thread : http://forums.arcgis.com/threads/21286-Charting-issues-in-10
