Error adding KML Layer
1479
01-31-2011 08:53 PM
linusang
I hit an exception when the KML layer is trying to read a line that reads:
<name>Chaîne des Puys</name>
the "î" in the word "Chaîne" throws an exception.. an solutions for it?
thanks
dotMorten_esri
Esri Notable Contributor
What exception are you getting? Could you share a sample app + kml that reproduces this error?
linusang
the kml is from http://www.volcano.si.edu/ge/gvp_world.kmz
just a simple
<esri:Map >
            <esri:ArcGISTiledMapServiceLayer Url="http://services.arcgisonline.com/ArcGIS/rest/services/ESRI_Imagery_World_2D/MapServer" />
            <esri:KmlLayer ID="KmlLayer" Url="uri to gvp_world.kml"
        </esri:Map>
would produce the error saying the character "î"  is not valid: (Invalid character in the given encoding. Line 84, position 10.)
BjørnarSundsbø
A bit late reply, but better with possibly answered posts than unresolved.....
I'm having a similar problem, where the file is in ANSI. A resolution is posted in another post. It could help you out.
Bjørnar Sundsbø
