Edits are not saved
1733
10-06-2011 03:20 PM
AjaySisodia2
Hello:
I developed an point editing application. I think i have all the requirements implemented (sde, feature layer, versioned - although not required).
I have tried both - auto save and manual save but edits are not saved.
Also the weird things is that after adding few points, fLayer.HasEdits returns false. What I am doing wrong or what I need to do to make it work?
Could somebody please help!
thanks in advance,
ajay -
JenniferNery
How are you editing the FeatureLayer? Can you share some code? Also, you may want to subscribe to FeatureLayer EndSaveEdits and SaveEditsFailed events to see why save failed.
http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.FeatureLay...
You can inspect EditResultItem from EndSaveEdits. http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Edit...
or see the Error from TaskFailedEventArgs http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.FeatureLay...
You can also run Fiddler with your app to monitor the web requests.
AjaySisodia2
hi Jennifer, thanks very much for your response.
I implemented the checks you mentioned.
I am getting this error:
{"error":{"code":400,"message":"Unable to complete  operation.","details":["Invalid graphic features","Invalid parameters"]}}
and the feature is: when added manually to the feature server.
"geometry":{"x":-9539817.27255194,"y":4613535.33509156,"spatialReference":{"wkid":102100}},
"attributes"{
"POIID":"113134"
i cleaned it up to remove the empty fields saved as null thinking that it may be that might be causing the issue, ex:
"ShortDescription":null,
"LongDescription":null,
The graphic point looks fine to me so not sure what is happening here. Any suggestion?
Do I need to change the spatial Reference?
AjaySisodia2
ok, i think i figured it out.
it adds the feature if the attributes ONLY with values are passed, so if request has some attribute such as "Description":null, it fails.
I have the custom form with DataContext=graphic.attributes and it loads all attributes in the form. The attributes not modified assume null values and hence passed at the time of feature save and then it fails.
I tried to use the updated fields list to explicitly save value as "" or remove it from the graphic but that  does not work either.
            foreach (KeyValuePair<string, object> kvp in _selectedPOI.Attributes)
                if (!dataEditorForm.updatedFieldsList.Contains(kvp.Key))
                    _selectedPOI.Attributes[kvp.Key] = "";
// OR             _selectedPOI.Attributes.Remove(kvp);
Any suggestions?
PaoloTovar
I had the same issue, i'm relatively new to silverlight but my particular issue was the feature service i was attempting to edit was based on a 3D feature dataset.
I create a new feature making sure there was no z and republished the service and it worked.
Hope this helps you,
Cheers!
Paolo
AjaySisodia2
hi Paolo:
Thanks for your response.
on researching it, also implementing the checks Jennifer recommended, i found that some field were set to not accept null in the db, fixing that solved the issue.
cheers,
ajay -
