EditorWidget - can't to save data  to the geodatabase
2025
12-04-2013 02:19 AM
AnatoliiTerentiev
I try to use EditorWidget control to edit layers with feature access. I can delete items from geodatabase (sql server express), but can't to save result of feature editing. If I try to edit existing feature after click "OK" button - this button becomes not active and data not saved even on the Map. If I try to edit new added feature - it normally saved on the map, but not saved in geodatabase.
    If I try use this layer in arcgis.com map , then all operation are performed normally and data properly saved in geodatabase.
XAML:
       <esri:Map x:Name="MyMap" Background="White" WrapAround="true" Extent="6095000,6810000,6900000,7258000">
            <i:Interaction.Triggers>
                <i:EventTrigger EventName="MouseEnter">
                    <ei:ChangePropertyAction TargetName="myMenuItems" PropertyName="Visibility">
                        <ei:ChangePropertyAction.Value>
                            <Visibility>Collapsed</Visibility>
                        </ei:ChangePropertyAction.Value>
                    </ei:ChangePropertyAction>
                </i:EventTrigger>
            </i:Interaction.Triggers>
            <esri:ArcGISDynamicMapServiceLayer ID="BaseLayer"
              Url="http://terentievai:6080/ArcGIS/rest/services/rk/MapServer" />
            <esri:ArcGISDynamicMapServiceLayer ID="chsLayer"
              Url="http://terentievai:6080/ArcGIS/rest/services/chs/MapServer" />
            <esri:FeatureLayer ID="myEvents" DisableClientCaching="True"
                               AutoSave="False"
                               Url="http://terentievai:6080/ArcGIS/rest/services/chs/FeatureServer/0"
                               OutFields="*"
                               Mode="OnDemand" />
        </esri:Map>
        <StackPanel Orientation="Vertical" HorizontalAlignment="Right" Margin="0,80,224,0"   VerticalAlignment="Top" >
            <esri:EditorWidget x:Name="MyEditorWidget"
                             Map="{Binding ElementName=MyMap}"
                                      Width="300"
                                      AutoSelect="False"
                                      AlwaysDisplayDefaultTemplates="True"
                                      GeometryServiceUrl="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"
                                      ShowAttributesOnAdd="True"
                                      Loaded="EditorWidget_Loaded"/>
        </StackPanel>
and code behind:
namespace Module2
    public partial class MapControl : UserControl
        public MapControl()
            InitializeComponent();
        private void ArcGISDynamicMapServiceLayer_Initialized(object sender, EventArgs e)
            ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer myArcGISDynamicMapServiceLayer =
                  MyMap.Layers["chsLayer"] as ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer;
            int[] myVisibleLayers = {0};
            myArcGISDynamicMapServiceLayer.VisibleLayers = myVisibleLayers;
        private void EditorWidget_Loaded(object sender, System.Windows.RoutedEventArgs e)
            string[] myLayerIDs = { "myEvents" };
            MyEditorWidget.LayerIDs = myLayerIDs;
And service details:
[HTML]Layer: events (ID: 0)
View In:   ArcGIS.com Map
Display Field: name
Type: Feature Layer
Geometry Type: esriGeometryPoint
Description:
Definition Expression: N/A
Copyright Text:
Default Visibility: true
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Min Scale: 0
Max Scale: 0
Supports Advanced Queries: true
Supports Statistics: true
Extent:
XMin: 6351082.909999
YMin: 6816741.669999
XMax: 6686624.070001001
YMax: 7331495.690001001
Spatial Reference: 28406  (28406)
Drawing Info:
Renderer:
Simple Renderer:
Symbol:
Label:
Description:
Transparency: 0
Labeling Info:
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field:
Fields:
id ( type: esriFieldTypeInteger , alias: id , editable: false , nullable: false )
status ( type: esriFieldTypeInteger , alias: status , editable: true , nullable: true )
name ( type: esriFieldTypeString , alias: name , editable: true , nullable: true , length: 255 )
dateTime ( type: esriFieldTypeDate , alias: dateTime , editable: true , nullable: true , length: 36 )
punct ( type: esriFieldTypeDouble , alias: punct , editable: true , nullable: true )
event_type ( type: esriFieldTypeInteger , alias: event_type , editable: true , nullable: true )
object ( type: esriFieldTypeInteger , alias: object , editable: true , nullable: true )
description ( type: esriFieldTypeString , alias: description , editable: true , nullable: true , length: 255 )
region ( type: esriFieldTypeDouble , alias: region , editable: true , nullable: true )
settle ( type: esriFieldTypeInteger , alias: settle , editable: true , nullable: true )
control ( type: esriFieldTypeSmallInteger , alias: control , editable: true , nullable: true )
dolgotaGrad ( type: esriFieldTypeInteger , alias: dolgotaGrad , editable: true , nullable: true )
dolgotaMin ( type: esriFieldTypeInteger , alias: dolgotaMin , editable: true , nullable: true )
dolgotaSec ( type: esriFieldTypeDouble , alias: dolgotaSec , editable: true , nullable: true )
dolgP ( type: esriFieldTypeString , alias: dolgP , editable: true , nullable: true , length: 1 )
shirotaGrad ( type: esriFieldTypeInteger , alias: shirotaGrad , editable: true , nullable: true )
shirotaMin ( type: esriFieldTypeInteger , alias: shirotaMin , editable: true , nullable: true )
shirotaSec ( type: esriFieldTypeDouble , alias: shirotaSec , editable: true , nullable: true )
shirP ( type: esriFieldTypeString , alias: shirP , editable: true , nullable: true , length: 1 )
harCHS ( type: esriFieldTypeInteger , alias: harCHS , editable: true , nullable: true )
infSorce ( type: esriFieldTypeString , alias: infSorce , editable: true , nullable: true , length: 255 )
mashtab ( type: esriFieldTypeInteger , alias: mashtab , editable: true , nullable: true )
data_loc ( type: esriFieldTypeDate , alias: data_loc , editable: true , nullable: true , length: 36 )
data_likv ( type: esriFieldTypeDate , alias: data_likv , editable: true , nullable: true , length: 36 )
X ( type: esriFieldTypeDouble , alias: X , editable: true , nullable: true )
Y ( type: esriFieldTypeDouble , alias: Y , editable: true , nullable: true )
ObjectID ( type: esriFieldTypeOID , alias: ObjectID , editable: false , nullable: false )
Templates:
Description:
Prototype:
Drawing Tool: esriFeatureEditToolPoint
Capabilities: Create,Delete,Query,Update,Uploads,Editing
Sync Can Return Changes: false
Is Data Versioned: false
Supports Rollback On Failure: true
Supported Operations:   Query   Apply Edits   Add Features   Update Features   Delete Features   Generate Renderer   Return Updates
[/HTML]
What could be wrong?
AnatoliiTerentiev
I try to test EditorWidget example , added  my layer with feature access "myEvents"
XAML:
<UserControl x:Class="Module2.MapControl"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:esri="http://schemas.esri.com/arcgis/client/2009">
    <Grid x:Name="LayoutRoot">
            <esri:FeatureLayer ID="Points of Interest" DisableClientCaching="True"
                               AutoSave="False"
                               Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0"
                               OutFields="*"
                               Mode="OnDemand" />
                               AutoSave="False"
                               OutFields="*"
                               Mode="OnDemand" />
        </esri:Map>
        <StackPanel  x:Name="EditorToolStrip" Margin="0,5,5,0" >
            <Border Background="#00919191" CornerRadius="5"
               HorizontalAlignment="Right"  VerticalAlignment="Top"
               Padding="5" BorderBrush="Transparent">
                <Border.Effect>
                    <DropShadowEffect Color="Black" Direction="-45" BlurRadius="20" Opacity=".75" />
                </Border.Effect>
                <StackPanel Orientation="Vertical" HorizontalAlignment="Right" Margin="0,5,5,0" VerticalAlignment="Top" >
                                      Width="300"
                                      AutoSelect="False"
                </StackPanel>
            </Border>
        </StackPanel>
    </Grid>
</UserControl>
and code behind:
namespace Module2
        public MapControl()
            string[] myLayerIDs = { "Points of Interest", "Evacuation Perimeter", "myEvents" };
The result of testing:
1. Layer "Points of interest" works normally. Result of editing saves normally.
2. Layer "myEvents" works as described in previous message.
Thus it can be assumed that the problem  is in the layer or  in  geodatabase. However, confuses that if test service in arcgis.com  MAP, the changes are saved for layer myEvents too.
AnatoliiTerentiev
Any ideas how to fix?
1. Can't anybody say what steps can I take to solve the problem?
2. Now I made connection to geodatabase from "sa" , temporarily. This connection I use in the service. Is it correct?
3. May be some checklist - did I all necessary?
