Editor widget, Template picker question
978
09-03-2010 12:57 PM
DanDulan
I have noticed that a feature is still created on the server if the user has closed the attribute entry form provided by the widget.
I would like to collect the attributes first, do some validation on the client and then create the feature on the server.
Any suggestions?
JenniferNery
You can refer to this forum post re: Undo editshttp://forums.arcgis.com/threads/9756-Undo-edits-of-the-EditorWidget
Basically you will need to set the FeatureLayer's AutoSave property to false and subscribe to TemplatePicker's Template Editor EditCompleted event to have control over SaveEdits(). In the event handler, you will have the chance to check the graphic attributes prior to calling SaveEdits().
DanDulan
Thanks Jennifer!
