Editor Widget (Attribute update issue)
4397
10
09-06-2011 06:20 AM
JerryBiedenbender
    I am using the editor widget in my silverlight application and am having a small issue with updating attributes. I can update every field except for the field that the symbology is based on. Does anyone know how to correct this issue?
Jerry
JenniferNery
Sure, you can try this. Before setting FeatureDataForm.GraphicSource, you can update the graphic attribute value first, if it is found to be null. This uses Linq query to search for all CodedValueDomain.
var fields  = l.LayerInfo.Fields.Where(f => f.Domain is CodedValueDomain && (f.Domain as CodedValueDomain).CodedValues.Count > 0);
foreach (var f in fields)
  if (g.Attributes[f.Name] == null)
    var d = f.Domain as CodedValueDomain;
    g.Attributes[f.Name] = d.CodedValues.FirstOrDefault().Key;
