Editing using EDITOR
920
02-10-2012 07:11 AM
Jitendrudulacaraju
I am trying to add point feature for a featurelayer (point geometry) using the EDITOR in the SL API. This is what I do, see code. I want a sample how this can be done.
<Button x:Name="btnAdd" Width="30" Height="30" Margin="120,-125,0,0" ToolTipService.ToolTip="Install a Sign"
                    cal:Click.Command="{Binding EditorAddCommand}"
                    cal:Click.CommandParameter=""
                    Visibility="{Binding EditButtonsVisibility}"
                <Button.Content>
                    <Image x:Name="imgMin4"
                               Source="/CoM.EGIS.Infrastructure;Component/Assets/Images/DrawPoint.png"
                               Stretch="Fill" HorizontalAlignment="Center" />
                </Button.Content>
            </Button>
#region Editor
        private void OnEditorAddCommand(string value)
            EditorAddCommand = SignsEditor.Add;
        private void Editing()
                    string[] layerids = new string[] { Map.Layers["TrafficSigns"].ToString(),"" };
                    SignsEditor.Map = this.Map;
                    SignsEditor.LayerIDs = layerids;
                    SignsEditor.GeometryServiceUrl = "http://memgisdev4.memphis.ad/ArcGIS/rest/services/Geometry/GeometryServer";
                    SignsEditor.EditorActivated += new EventHandler<Editor.CommandEventArgs>(SignsEditor_EditorActivated);
                    SignsEditor.EditCompleted += (SignsEditor_EditCompleted);
        private void SignsEditor_EditCompleted(object sender, Editor.EditEventArgs e)
        // show the data on the form
            foreach (Editor.Change change in e.Edits)
                if (change.Layer != null && change.Layer is FeatureLayer && change.Graphic != null)
                    FeatureLayer featureLayer = change.Layer as FeatureLayer;
                    //set the form values with a new PUKID which
        public string LayerID { get; set; }
        private void SignsEditor_EditorActivated(object sender, Editor.CommandEventArgs args)
            OnEditorActivated(args);
        /// <summary>
        /// Occurs when an editor has been activated.
        /// </summary>
        public event EventHandler<Editor.CommandEventArgs> EditorActivated;
        private void OnEditorActivated(Editor.CommandEventArgs args)
            EventHandler<Editor.CommandEventArgs> handler = EditorActivated;
            if (handler != null)
                handler(this, args);
        private void OnEditCompleted(Editor.EditEventArgs args)
JenniferNery
You can look at the following SDK sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#EditToolsExplicitSave
   <Grid.Resources>
            <esri:Editor x:Key="MyEditor"
                         Map="{Binding ElementName=MyMap}"
                         LayerIDs="ThreatAreas"
                         GeometryServiceUrl="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"
        </Grid.Resources>
 <Button Command="{Binding Add}" Margin="2"  DataContext="{StaticResource MyEditor}"
                         Content="Add Polygon">
                        <Button.CommandParameter>
                            <sys:Int32>10301</sys:Int32>
                        </Button.CommandParameter>
                    </Button>
Note that 10301 is a FeatureType from this service: http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/FeatureServer...
