Attribute Query(Samples) - Performing similar operation to a "Table" with Zoom to fun
843
02-09-2012 04:34 AM
srikanthpilli
Can we perform attribute query to a "Table" published as a service - similar to the one in samples,  provided that the table has all UTM co-ordiantes populated for each row.?
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#AttributeQuery.
Appreaciate for taking you time and providing your suggestions.
Thanks!
JenniferNery
Sure you can use the table URL as your QueryTask.URL, this should return you Attributes but no Geometry would be returned. If Geometry is an Attribute or Field in your table, then you can still zoom to this location. For example
MyMap.ZoomTo(g.Attributes["MyLocation"] as Polygon);
srikanthpilli
Thank you, Jennifer for taking time to give your inputs on it.
