Dropping and georectifying images on map
2619
12-15-2011 06:47 AM
LizCarter1
I looked through the forum first but couldn't find an answer to this question.
Is it possible to drop an image such as a jpg or nitf onto a Silverlight ArcGIS map and then georectify it?
DominiqueBroux
Esri Frequent Contributor
Not sure what you mean by 'georectify'.
The closest sample is this one : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MediaLayer
but the georectification is relatively basic (scale, rotation, placement).
LizCarter1
That is exactly what I'm talking about.  What formats of images videos can this be done with?  Where can I find the directions for doing this?
dotMorten_esri
Esri Notable Contributor
See this sample as well which helps you generate the xaml needed for placing the image/video/xaml/whatever:
http://www.arcgis.com/home/item.html?id=2ef4c343494647cc82b64a2d421d5716
The approach works with any image or video that Silverlight supports.
