Drive Time - Error on GeoprocessorTask_ExecuteCompleted
821
10-13-2010 11:39 AM
ShaningYu
Honored Contributor
I loaded ESRI' source code for Drive Times from http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#DriveTimes.
However, I got 1 error at
           _geoprocessorTask.ExecuteCompleted += GeoprocessorTask_ExecuteCompleted;
Error 1 The call is ambiguous between the following methods or properties: 'UnBlendedCS1_Oct1.DriveTime.GeoprocessorTask_ExecuteCompleted(object, ESRI.ArcGIS.Client.Tasks.GPExecuteCompleteEventArgs)' and 'UnBlendedCS1_Oct1.DriveTime.GeoprocessorTask_ExecuteCompleted(object, ESRI.ArcGIS.Client.Tasks.GPExecuteCompleteEventArgs)'
Thanks for your review and provide your hint for the solution.
JenniferNery
Ambiguous call means you have defined that method more than once so it is unsure which method to call. Find all references on GeoprocessorTask_ExecuteCompleted, to see if it was duplicated.
