Draggable Window
1361
5
06-04-2010 08:15 AM
DanDulan
I am trying to use the the DraggableWindow control from Silverlight Showcase Application in my application (using Silverlight Bussiness Application template).
The problem I have is that if I drag the control over the navigation grid (on top of the page) the control goes under the border and I can't get it back.
DeminHu
After read your post, I tested one of my old application which started from Showcase sample, it was fine for me.
I think the problem may not from dragablewindow, try to change your layout, for example, put map, Nav gird, dragable window on the same parent Grid to see if it will work.
DanDulan
Thanks Demin!
I have a main page as a starting page and three views.
On the main page I have a frame to handle the navigation, a border around a logo and  three hiperlink buttons.
On each view I use draggable window controls and they function fine regarding the rest of the view but they go under the controls on the main page.
I looked into the draggable window code and the MouseLeftButtonDown event is hooked to the Application.Current.RootVisual.MouseMove.
I have noticed the some of  sample websites posted on Code Gallery have the same problem.
ManojrajTeli
So anyone found the solution...???Because i am also finding the same problem...
JenniferNery
Can you share the StackTrace with us? Thanks.
ManojrajTeli
Thanks Jennifer Nery i feagured out the solution.I just wrote the statement "<ResourceDictionary Source="/"[APPLICATION SOLUTION NAME]";component/UserControls/CollapsiblePanel.xaml" />" in Themes/generic.xaml file.
