Disable default map navigation options
1600
06-16-2011 06:51 AM
PhilippeSteinthal
I need to disable some of the default map navigation options like
Left mouse + Sthif Key + Drag  Drags a zoom box and zooms to the box.
Left mouse + Shift + Ctrl Key + Drag  Drags a zoom box and zooms out around the box.
But in general terms how can that be handled using wpf for the map.
JenniferNery
If you subscribe to Map.MouseLeftButtonDown and set e.Handled = true, this will prevent pan and zoom.
PhilippeSteinthal
How about the selection box that comes up with the shift.We do not need it either and the list goes on...
Is not there a wpf way to undo these pre-defined ESRI behavior rather than trying to do it after the fact?
JenniferNery
When MouseLeftButtonDown is marked handled, you will not get the envelope used for zooming in/out so the Shift/Ctrl-keys are not even evaluated. Map navigation is disabled.
