Determine queryable/selectable layers
2181
09-08-2011 09:15 PM
De_WetEllis
Hi
I am having problems with my viewer I created. The Viewer allows a user to select a layer from a dropdown and from that layer use the Query tools to query that specific layer. To populate the Dropdown I just looped through all visibles layers. But the problem is that the Service/MXD contains another service ( Almost like a BASEMAP ) . But that layer is an Image Service. And also Unselectable.
The problem is that the client designed this MXD and I cant change anything.
Now the query task fails on that layers.
How can I determine all the layers that are queryable/selectable. I cannot find a property on LayerInfo. Only if its visible. The viewer is not specific to a Service. Its a plug in viewer and should work on any Service I specify.
Any Solutions or Suggestions on how to get this list of layers. I am using an ArcGISDynamicMapServiceLayer.
Specs:  ARCGIS 10 , API 2.2 , Silverlight 4 , C#
De Wet
De_WetEllis
Hi
Okay , I was thinking about this issue. And maybe there is a different Solution. But I still need help on doing this.
The Background layer doesnt have a featureclass. So how can I determine if the Layer has a feature class. Then if the Feature Class is Null then I know its a background layer. ( Something like that ).
The Layerinfo for each layer within a ArcGISDynamicMapServiceLayer doesnt show me anything regarding the Capabilities of the Layer.
Any suggestions Please.
Thanks.
De Wet
DominiqueBroux
Esri Frequent Contributor
One way is you to query the layers resource of the map service and deserialize the response by yourself:
   - documentation : http://help.arcgis.com/en/arcgisserver/10.0/apis/rest/layers.html
   - sample : http://services.arcgisonline.com/ArcGIS/rest/services/Demographics/USA_Percent_Over_64/MapServer/lay...
The type field is giving you the type of layer (Feature Layer, Raster, Group Layer, ....)
De_WetEllis
Hi Dominique
Thanks for the Reply. This could be very usefull.
While debugging this morning I found this.
On my Legend_Refreshed the LayerItems is of Type LayerItemViewModel.
Foreach LayerItemViewModel it has a Property "LayerType" that specifies what layer it is.
Like LayerType = "Feature Layer" or LayerType = "Group Layer".
I am using a Legend so in this case this will work but in a case where you are not using a legend and need Layer Information the solution you provided will work.
Thanks A Lot.
De Wet
