Detect Authentication Challenge from Feature Layer?
1038
11-01-2012 10:55 AM
MattMiley
Is it possible to Detect Authentication Challenge from a feature layer?
Then i can make the sign in dialog visible only whenever this challenge happens?
DominiqueBroux
Esri Frequent Contributor
The simplest way to activate the IdentityManager is to initialize a challenge method using the built-in SignInDialog (sample).
Something like:
IdentityManager.Current.ChallengeMethod = SignInDialog.DoSignIn;
The sign in dialog will automatically show up when an authentication is needed.
For advanced scenarios, you can also create you own challenge method and react differently depending on the server url.
RichardWatson
I don't think that this is what you are looking for but you could programmatically send an HTTP request to the feature layer(s) and parse the response(s) yourself.
MattMiley
That just sounds like too much work, I guess I hoping for some kind of event to be able to watch for to know when to display the signin dialog and or make it disappear whenever there aren't any layers challenging for Authentication.
DominiqueBroux
Something like:
