DataGrid on Click
4383
01-31-2012 11:48 AM
by Anonymous User
Not applicable
Original User: vaayu
Working with my first silverlight API as web App in cs.  I'm trying to create a "Find" task on my map using the link
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Find
I do get the results from my layer but, when I click i get the error attached.  I don't see any marker highlighted and also wondering if there was a way to create some Right click options on the data grid for the row, like zoom to feature etc.,
Appreciate any help!
DominiqueBroux
Esri Frequent Contributor
Looks like you didn't create the GraphicsLayer in XAML.
In the sample you pointed out, there is this XAML line:
            <esri:GraphicsLayer ID="MyGraphicsLayer" />
Check that you didn't forget it in your project.
DominiqueBroux
by Anonymous User
Not applicable
Thank you Dominique.. That was hit..but, my point is not highlighted for some reason.  It finds the record in the grid but, when I click on it, I dont see anything highlighted.  Any thoughts?
DominiqueBroux
This thread is about the same kind of issue.
This might give you some clue about your issue (bad binding?, bad symbol?)
