Data Extraction Based on Featuredatagrid
1053
06-07-2013 08:14 AM
chengbiliu
Hello!
I would like to create a data extraction function for the feature layers in my map. The online sample http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#ExtractData allows the user to clip the features and download data. However, is there a way to download the data based on features selected in featuredatagrid? I would like users to select features in the data grid and extract their attributes by clicking a "download" button. Can anyone tell me how the xaml and code-behind should look like? In specific, what part of the c# code in the sample controls the actual extraction (not clipping or drawing) method? And how should I call it in xaml?
My current data grid xaml code looks like this:
<esri:FeatureDataGrid Grid.Row="2"
              x:Name="MyDataGrid"
              GraphicsLayer='{Binding ElementName=QueryComboBox, Path=SelectedItem}'
              AutoGenerateColumns='True'></esri:FeatureDataGrid>
The c# code of the sample is this:
using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Net;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Threading;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Geometry;
using ESRI.ArcGIS.Client.Symbols;
using ESRI.ArcGIS.Client.Tasks;
namespace ArcGISSilverlightSDK
    public partial class ExtractData : UserControl
        private Draw _drawObject;
        Geoprocessor _geoprocessorTask;
        private DispatcherTimer _processingTimer;
        Stream _streamedDataFile;
        GraphicsLayer _graphicsLayer;
        public ExtractData()
            InitializeComponent();
            _processingTimer = new System.Windows.Threading.DispatcherTimer();
            _processingTimer.Interval = new TimeSpan(0, 0, 0, 0, 800);
            _processingTimer.Tick += ProcessingTimer_Tick;
            _geoprocessorTask = new Geoprocessor("http://sampleserver4.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/Incident_Data_Extraction/GPServer/Extract%20Data%20Task");
            _geoprocessorTask.GetServiceInfoCompleted += _geoprocessorTask_GetServiceInfoCompleted;
            _geoprocessorTask.Failed += _geoprocessorTask_Failed;
            _geoprocessorTask.UpdateDelay = 5000;
            _geoprocessorTask.JobCompleted += _geoprocessorTask_JobCompleted;
            _geoprocessorTask.GetResultDataCompleted += _geoprocessorTask_GetResultDataCompleted;
            _geoprocessorTask.GetServiceInfoAsync();
            _drawObject = new Draw(MyMap)
                LineSymbol = LayoutRoot.Resources["CustomAnimatedRedLineSymbol"] as LineSymbol,
                FillSymbol = LayoutRoot.Resources["CustomAnimatedRedFillSymbol"] as FillSymbol
            _drawObject.DrawComplete += MyDrawObject_DrawComplete;
            _graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
        private void DrawPolygon_Click(object sender, RoutedEventArgs e)
            _graphicsLayer.ClearGraphics();
            if (FreehandCheckBox.IsChecked.Value)
                _drawObject.DrawMode = DrawMode.Freehand;
            else
                _drawObject.DrawMode = DrawMode.Polygon;
            _drawObject.IsEnabled = true;
        private void FreehandCheckBox_Checked(object sender, RoutedEventArgs e)
            else
        void _geoprocessorTask_GetServiceInfoCompleted(object sender, GPServiceInfoEventArgs e)
            LayersList.ItemsSource = e.GPServiceInfo.Parameters.FirstOrDefault(p => p.Name == "Layers_to_Clip").ChoiceList as object[];
            Formats.ItemsSource = e.GPServiceInfo.Parameters.FirstOrDefault(p => p.Name == "Feature_Format").ChoiceList as object[];
            if (Formats.ItemsSource != null && Formats.Items.Count > 0)
                Formats.SelectedIndex = 0;
        private void MyDrawObject_DrawComplete(object sender, ESRI.ArcGIS.Client.DrawEventArgs args)
            if (LayersList.SelectedItem == null)
                MessageBox.Show("Please select layer(s) to extract");
                (MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer).ClearGraphics();
                return;
            Geometry filterGeometry = args.Geometry;
            if (args.Geometry is Polyline)
                Polyline freehandLine = args.Geometry as Polyline;
                freehandLine.Paths[0].Add(freehandLine.Paths[0][0].Clone());
                filterGeometry = new Polygon() { SpatialReference = MyMap.SpatialReference };
                (filterGeometry as Polygon).Rings.Add(freehandLine.Paths[0]);
            ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
                Geometry = filterGeometry
            _graphicsLayer.Graphics.Add(graphic);
            _drawObject.IsEnabled = false;
            ProcessingTextBlock.Visibility = Visibility.Visible;
            _processingTimer.Start();
            List<GPParameter> parameters = new List<GPParameter>();
            var strLayerList = new List<GPString>();
            foreach (var itm in LayersList.SelectedItems)
                strLayerList.Add(new GPString(itm.ToString(), itm.ToString()));
            parameters.Add(new GPMultiValue<GPString>("Layers_to_Clip", strLayerList));
            parameters.Add(new GPFeatureRecordSetLayer("Area_of_Interest", _graphicsLayer.Graphics[0].Geometry));
            parameters.Add(new GPString("Feature_Format", Formats.SelectedValue.ToString()));
            _geoprocessorTask.SubmitJobAsync(parameters);
        void _geoprocessorTask_JobCompleted(object sender, JobInfoEventArgs e)
            if (e.JobInfo.JobStatus != esriJobStatus.esriJobSucceeded)
                MessageBox.Show("Extract Data task failed to complete");
                return;
            _geoprocessorTask.GetResultDataAsync(e.JobInfo.JobId, "Output_Zip_File");
        void _geoprocessorTask_GetResultDataCompleted(object sender, GPParameterEventArgs ev1)
            if (ev1.Parameter is GPDataFile)
                GPDataFile ClipResultFile = ev1.Parameter as GPDataFile;
                if (String.IsNullOrEmpty(ClipResultFile.Url))
                    return;
                MessageBoxResult res = MessageBox.Show("Data file created. Would you like to download the file?", "Geoprocessing Task Success", MessageBoxButton.OKCancel);
                if (res == MessageBoxResult.OK)
                    WebClient webClient = new WebClient();
                    webClient.OpenReadCompleted += (s, ev) =>
                        _streamedDataFile = ev.Result;
                        SaveFileButton.Visibility = Visibility.Visible;
                        ProcessingTextBlock.Text = "Download completed.  Click on 'Save data file' button to save to disk.";
                    webClient.OpenReadAsync(new Uri((ev1.Parameter as GPDataFile).Url), UriKind.Absolute);
                else
                    ProcessingTextBlock.Text = "";
                    ProcessingTextBlock.Visibility = Visibility.Collapsed;
                    SaveFileButton.Visibility = Visibility.Collapsed;
            _processingTimer.Stop();
        void _geoprocessorTask_Failed(object sender, TaskFailedEventArgs e)
            MessageBox.Show("Extract data task failed: " + e.Error.Message);
        private void ResetButton_Click(object sender, System.Windows.RoutedEventArgs e)
        void ProcessingTimer_Tick(object sender, EventArgs e)
            if (ProcessingTextBlock.Text.Length > 20 || !ProcessingTextBlock.Text.StartsWith("Processing"))
                ProcessingTextBlock.Text = "Processing.";
            else
                ProcessingTextBlock.Text = ProcessingTextBlock.Text + ".";
        private void SaveFileButton_Click(object sender, RoutedEventArgs e)
            SaveFileDialog dialog = new SaveFileDialog();
            dialog.DefaultFileName = "Output.zip";
            dialog.Filter = "Zip file (*.zip)|*.zip";
            bool? dialogResult = dialog.ShowDialog();
            if (dialogResult != true) return;
            try
                using (Stream fs = (Stream)dialog.OpenFile())
                    _streamedDataFile.CopyTo(fs);
                    fs.Flush();
                    fs.Close();
                    ProcessingTextBlock.Text = "Output file saved successfully!";
                    _streamedDataFile = null;
            catch (Exception ex)
                MessageBox.Show("Error saving file :" + ex.Message);
Thanks a lot in advance!
