custom printing
2786
03-02-2013 12:32 AM
samehsaras
I used ArcGIS Server 10.1 ,and i created some layout template(MXD) , i registed custom folder and create new Print service tools and publish GP result . when i use GP Service (Print) using Silverlight API 3.0 occutred this error .
please any body help me
DominiqueBroux
Esri Frequent Contributor
Likely PrintResult is null becasue you got an erro during the print process.
I suggest you change the PrintCompleted Handler by this one:
private void printTask_PrintCompleted(object sender, PrintEventArgs e)
    if (e.Error != null)
        MessageBox.Show("Error:" + e.Error.Message);
    else
        System.Windows.Browser.HtmlPage.Window.Navigate(e.PrintResult.Url, "_blank");
The error, which will be displayed in a message box, might give a clue about the origin of the problem.
samehsaras
i changes my code and i made handleing error . the error is changed "Error Performing Execute Operation". any body help me
JohanCarlsson
Hard to say without seeing any of your code, but it could be something wrong with the printparamters that you supply when you execute the operation.
