Custom LegendItemTemplate
2863
10-15-2011 06:58 AM
SantoshV
HI,
I am using a Legend template...
Here I want to show the polyline length which I query from the database
<esri:Legend Map="{Binding ElementName=map}" MaxHeight="300" MinHeight="100"
                         LayerItemsMode="Tree"
                         ShowOnlyVisibleLayers="True" x:Name="CustomLegend" >
                    <esri:Legend.MapLayerTemplate>
                        <DataTemplate>
                            <StackPanel Orientation="Horizontal">
                                <CheckBox Content="{Binding Label}"/>
                                <!--<Slider Maximum="1" Value="{Binding Layer.Opacity, Mode=TwoWay}" Width="50" />-->
                            </StackPanel>
                        </DataTemplate>
                    </esri:Legend.MapLayerTemplate>
                    <esri:Legend.LegendItemTemplate>
                        <DataTemplate >
                            <StackPanel Orientation="Horizontal" x:Name="stackpanel1">
                                <Image Source="{Binding ImageSource}"></Image>
                                <sdk:Label Content="{Binding Label}" MinWidth="40"/>
                                <sdk:Label Content="{Binding Keys}" MinWidth="50"/>
                            </StackPanel>
                        </DataTemplate>
                    </esri:Legend.LegendItemTemplate>
                    <esri:Legend.LayerTemplate>
                        <DataTemplate>
                           IsChecked="{Binding IsEnabled, Mode=TwoWay}"
                        IsEnabled="{Binding IsInScaleRange}" >
                            </CheckBox>
                        </DataTemplate>
                    </esri:Legend.LayerTemplate>
                </esri:Legend>
how do I bind the values that I have in a Dictionary?
Please guide..
DominiqueBroux
Esri Frequent Contributor
One way is you to use the LayerItemViewModel  'Tag' property to store your length.
You can initialize the 'Tag' property by code on event legend 'Refreshed' and then just display it with a Binding to Tag.
For more complex scenarios, you can also set the Tag property to a dictionary and use a binding such as {Binding Tag[Length]}   (by supposing your dictionary has a 'Length' entry)
SantoshV
Hi thank you for your reply I tried doing it the way you suggested
void CustomLegend_Refreshed(object sender, ESRI.ArcGIS.Client.Toolkit.Legend.RefreshedEventArgs e)
            if (boolRefreshLegend)
                string[] str = new string[lstRoadSurfaceTypes.SelectedItems.Count];
                for (int i = 0; i < lstRoadSurfaceTypes.SelectedItems.Count; i++)
                    KeyValuePair<int, string> ListItemKeyValuePair = (KeyValuePair<int, string>)lstRoadSurfaceTypes.SelectedItems;
                    str = ListItemKeyValuePair.Value;
                e.LayerItem.Tag = "52 kms";
                var fLayer = e.LayerItem.Layer as FeatureLayer;
                if (fLayer != null && fLayer.ID == "Road Surface Type" && e.LayerItem.LegendItems != null)
                    var toRemove = e.LayerItem.LegendItems.Where(item => item.Label != str[0]).ToArray();
                    int intLegendItemCount = e.LayerItem.LegendItems.Count;
                    for (int i = 0; i < str.Count(); i++)
                        toRemove = toRemove.Where(item => item.Label != str).ToArray();
                    LegendItemViewModel itemmodel = mainPage.CustomLegend.LayerItems[0];
                    itemmodel .Tag = "Black Top";
                    foreach (var item in toRemove)
                        e.LayerItem.LegendItems.Remove(item);
                        <DataTemplate >
                                <sdk:Label x:Name="label1" Content="{Binding Tag}" MinWidth="40"/>
                            </StackPanel>
                        </DataTemplate>
Please guide me here
SantoshV
Thank you tag worked
            dicSurfaceLength = e.Result;
            foreach (LegendItemViewModel legendItems in mainPage.CustomLegend.LayerItems[0].LegendItems)
                legendItems.Tag = e.Result[legendItems.Label];
