custom Action on Editor_EditCompleted event
1850
7
10-31-2011 03:47 AM
NoureddineEl-zaatari
Hello,
im using the the Editor with custom commands to create an editing application, everything works fine but for deleting a feature i would like to do the following, update an attribute,, i was looking at the REST url and found out there Edit-Delete-Update operations available but never found a way to access them.
private void Editor_EditCompleted(object sender, Editor.EditEventArgs e)
            if (e.Action == Editor.EditAction.DeleteSelected)
i started fiddler and found out that it is calling applyedits through REST,
is there any direct way to update attributes instead of deleting them ?
thanks for any help
JenniferNery
Sure, instead of using Command Binding to Editor.DeleteSelected, you can use Button.Click event and in the event handler, iterate through the SelectedGraphics and set the attribute of interest.
If you are using EditorWidget, you can customize the control by following these steps: http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2010/05/28/Localizing-ArcGIS-Controls.aspx. In the EditorWidget.Style, you will find that there is a button that binds to DeleteSelected command, subscribe to its Click event instead.
If you are using Editor (similar to this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#EditToolsExplicitSave), you will find a button that binds to DeleteSelected command, subscribe to its Click event instead.
thanks, exactly what i was looking for
one more thing, after i do the custom changes to the selected graphics, how do i tell the editor that i did some changes so that it enabled the save command button ??
i think that im doing something wrong,
after doing the changes i check if FeatureLayer.Hasedits and it is always giving me false,,
here is my code on the button event handler
Editor editor = LayoutRoot.Resources["MyEditor"] as Editor;
            foreach (GraphicsLayer graphicsLayer in editor.GraphicsLayers)
                if (graphicsLayer is FeatureLayer)
                    foreach (Graphic g in graphicsLayer.SelectedGraphics)
                        g.Attributes["isDeleted"] = 1;
                    FeatureLayer flayer = graphicsLayer as FeatureLayer;
                    flayer.SaveEdits();
                    flayer.SaveEditsFailed += new EventHandler<ESRI.ArcGIS.Client.Tasks.TaskFailedEventArgs>(flayer_SaveEditsFailed);
thanks for helping
ChristopherHill
                    flayer.SaveEdits();
By default FeatureLayer.AutoSave = true which means you don't have to call SaveEdits() to push your change back to the service. As soon as you edit the graphic the feature layer will push the changes back to the service. If you set FeatureLayer.AutoSave = false then you have to call SaveEdits() and you see FeatureLayer.HasEdits = true when you make changes. Also you can wire up EndSaveEdits to see when something is getting saved back through the service.
                    flayer.EndSaveEdits += new EventHandler<ESRI.ArcGIS.Client.Tasks.EndEditEventArgs>(flayer_EndSaveEdits);
                    flayer.SaveEdits(); // <-- only need to call this if AutoSave is false
hi,
i think that updating is not working, there something wrong with my code maybe..
from the picker template i can create features, and the delete button when it was bound to Editor it was deleting also with no problems, but the custom delete button way is not updating my data on the server
FeatureLayer AutoSave is false and im calling saveEdits()
but events
- flayer_BeginSaveEdits
- flayer_SaveEditsFailed
- flayer_EndSaveEdits
are never triggered
private void Button_Click(object sender, RoutedEventArgs e)
                    flayer.BeginSaveEdits += new EventHandler<ESRI.ArcGIS.Client.Tasks.BeginEditEventArgs>(flayer_BeginSaveEdits);
                    flayer.SaveEdits();
                    flayer.Update();
any idea what is heppening ?
nevermind i got it all working well in fact it was my mistake,, FieldName Spelling was wrong..
and regarding events, create an event handler on the FeatureLayer it self, not on the casted Graphics Layer.. hope it helps others..
thank you for your help and support
