Creating envelope in API 3.0, Silverlight 5
1888
7
06-11-2012 03:12 PM
TanyaOwens
I am converting a project I had in API 2.4 Silverlight 4 into 3.0 and SL 5, when creating an envelope I get the error "The type or namespace name 'Envelope' could not be found (are you missing a using directive or an assembly reference?)" I check my using directives and references and everything matches my original project. Any suggestions?
DominiqueBroux
Esri Frequent Contributor
using references of ESRI.ArcGIS.Client, Client.Symbols, Client.Tasks, and Client.ValueConverters. Any suggestions?
Envelope is in the namespace ESRI.ArcGIS.Client.Geometry so you need this using reference as well (not a 3.0 change though).
DominiqueBroux
That smeels a dll version mismatch.
Double check that in your project all referenced ArcGIS dlls are ArcGIS SL 3.0.
Clean your project.
Exit Visual studio.
Remove bin, obj and clientbin directories.
Reopen Visual Studio
Try again.
That should work.
TanyaOwens
Clean your project.
Exit Visual studio.
Try again.
That should work.
I checked my referenced ArcGIS dlls and all say 3.0 in for the version. I followed the rest of the steps you suggested and it still doesn't recognize "envelope". I  have the ESRI references: ESRI.ArcGIS.Client, Behaviors, Toolkit and Toolkit.DataSources and using references of ESRI.ArcGIS.Client, Client.Symbols, Client.Tasks, and Client.ValueConverters. I also started a new project with only the ESRI.ArcGIS.Client reference and using directory and it also didn't recognize "envelope".  Any suggestions?
DominiqueBroux
TanyaOwens
oops!!! I totally missed that one when transferring it over. It works now. Thanks!!
JoeHershman
If you have that error, you can place your Cursor over the class name that is in red that throws the error.  Edit > Intellisense > Resolve and it will show you what using statement is missing and add it for you.
-Joe
TanyaOwens
Thanks!! That tip is going to help.
JoeHershman
Your welcome, and feel free to give points for any helpful post by clicking the up arrow 🙂
-Joe
