Create PDF ?
25324
76
07-20-2010 06:02 AM
CraigPerreault
Does anyone have a code sample to create a PDF file using the Silverlight API?
MarkCederholm
Sorry, I should have been more specific.  In PDFExporter.cs, comment out all the _streamOutPDF lines and move your SaveFileDialog lines to just before the document.Save line.  If that's actually the problem, then I'll revise the class accordingly.
KevinSesock
Attempting to set a WriteTimeout (System.IO.Stream.WriteTimeout) on PDFstream.WriteTimeout =4000; fails with "Timeouts are not supported on this stream". I'm stumped, as I have no idea what alternatives I have.
Leave it to me to find the one situation that is just plain bizarre.
You're right though, when you say that it is taking a while. I think I can time the whole operation on my watch, it's easily over 5 seconds.
KevinSesock
Close. Unfortunately SaveFileDialog has to be called by a user-initiated event, like a Button_Click event. I created a new property for a SaveFileDialog object, and passed it in from my Button_Click event after showing the dialog, then created the stream from the SaveFileDialog.OpenFile() method inside PDFExporter.cs. Thanks for the suggestion, I now have a PDF file to work with.
Unfortunately, I seem to be missing layers. How exactly does your class determine the order of your layers?
KevinSesock
Not only am I missing layers, but a Dynamic Service Layer is drawing... oddly. As in, the colors of the Dynamic Service Layer are messed up. I assume this is in the bmp conversion method. Any thoughts?
Mark:
I'd be happy to email you the pdfs that were output if you'd like to take a look. Otherwise I'll debug later, right now I've got to get other things taken care of in my app, so maybe I can find a fix if you don't have the time.
TomArnold1
Can someone send an example of they are using the export to pdf?  Thank you.
CraigPerreault
using PdfSharp.Pdf;
        private void PDFbutton_MouseLeftButtonUp(object sender, MouseEventArgs e)
                    SaveFileDialog savePDF = new SaveFileDialog();
                    savePDF.Filter = "PDF file format|*.pdf";
                    savePDF.DefaultExt = ".pdf";
                    if (savePDF.ShowDialog() == true)
                        System.IO.Stream PDFstream = savePDF.OpenFile();
                        PDFExporter PDFNew = new PDFExporter();
                        PDFNew.SetMap(myMap);
                        PDFNew.SetOutputStream(PDFstream);
                        PDFNew.DoExport();
DavidAshton
Can someone tell me where to place the download dll from the PDF libary: http://silverpdf.codeplex.com/
I tried to register the PDF library silverPDF.dll but no luck
So I just added it to my vs project as a ref.... but I'm getting an error message stating it could load the assembly file silverPDF.dll
If I go to the file and right click it and click register.  The "Register ArcGIS Assembly" dialog window pops up.  I can either select Desktop or Server.  I tired both and they both give me the error "Registration Failed" - Could not load file or assembly 'System Windows, Version = 2.0.5.0 culture=neutral, PublicKeyToken 7cec85d7bea7798e or one of its dependencies.  The system cannont find the specified.
O.K. Here's a little more info.  After just adding it to the references in VS I ran debug and got an error stating it was being blocked but I unblocked it after downloading so I went into the debug directory and unblocked again.  No the application luanches but it just hangs and never gets past the original silverlight blue logo.  When I take out all the PDF stuff the app is fine.
DavidAshton
I got it....
Thanks Kevin! Great Tool.
VikramS
Hi DAvid ,
Can u please tell me how did u register silver.dll . I am also getting the same error .. Thank u very much
I got it....
DavidAshton
I just opened my project in VS.
Right click on References
Click Add Reference
Click the Browse button and browse to the dll.  This add the dll to your VS project
