Converting ArcObjects to client geometries
1055
03-15-2011 10:11 PM
madormapad
Is there a simple way of converting ArcObjects geometries (ESRI.ArcGIS.Geometry) to client geometries (ESRI.ArcGIS.Client.Geometry)?
For example, converting ESRI.ArcGIS.Geometry.IPointCollection to ESRI.ArcGIS.Geometry.PointCollection.
I tried to create new points and copy the coordinates and spatial reference to the new PointCollection, but it takes forever.
I'm using ArcGIS Desktop 9.3.
Thank you.
JenniferNery
I have not worked with ArcObjects but I found this blog post. I think you would need to do the reverse: http://weblogs.asp.net/albertpascual/archive/2009/04/06/serializing-json-geometry-objects-between-si...
madormapad
Thank you very much for your answer 🙂
Strangely, using IPointCollection.QueryPoint instead of IPointCollection.get_Point (or IPointCollection.Point) solved the performance issue.
A convertion that took 12 seconds now takes about 0.25 seconds.
