Controlling content of a DataTemplate
2030
8
11-14-2011 04:14 AM
PaulHuppé
Is there a way to control the content of a DataTemplate depending on the value of a map layer label?  Below is part of my template.  What I want to do is to display an hyperlink for all map layers, but not for the Graphic Layer.  So, for all layers, I want to use the Hyperlink control and not show the CheckBox. And for the GraphicLayer, I want to show the CheckBox instead of the Hyperlink control.  Is there an easy way to do this?
Paul
    <esri:Legend.MapLayerTemplate>
     <DataTemplate>
      <StackPanel Orientation="Horizontal">
                            <CheckBox Content="{Binding Label}"
         IsChecked="{Binding IsEnabled, Mode=TwoWay}"
         IsEnabled="{Binding IsInScaleRange}" >
                            </CheckBox>
                            <HyperlinkButton Content="{Binding Label}" TargetName="_new" NavigateUri="http://www.nrcan.gc.ca/">
                                <ToolTipService.ToolTip>
                                    <StackPanel MaxWidth="400">
                                        <TextBlock FontWeight="Bold" Text="Show Metadata - Opens in new window" TextWrapping="Wrap" />
                                    </StackPanel>
                                </ToolTipService.ToolTip>
                            </HyperlinkButton>
dotMorten_esri
Esri Notable Contributor
Create a custom value converter that flips visibility based on the type of the layer.
http://msdn.microsoft.com/en-us/library/system.windows.data.ivalueconverter(v=vs.95).aspx
DominiqueBroux
Esri Frequent Contributor
There are more infos about what Morten suggests in this thread.
PaulHuppé
Thanks both of you. I will start on building a converter. Always something new to learn!
Paul
PaulHuppé
Question about the converter:
When I look at the samples, the converter is defined as:
public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
   return value is GraphicsLayer ? Visibility.Visible : Visibility.Collapsed;
Is it possible to have more than one parameter?  Can I do something like:
public object Convert(object value, Type targetType, object parameter1, object parameter2, System.Globalization.CultureInfo culture)
   // do something using the parameters which would set a visibility variable
   return visibility //return the value of my variable
and in my XAML, I would have something like:
                                Visibility="{Binding Layer, Converter={StaticResource VisConverter}, ConverterParameter=Layer, ConverterParameter='a string here'} " >
                            </CheckBox>
PaulHuppé
Found a way to do what I wanted with only one parameter.  But I am still interested to know if we can have more than one parameter.
JenniferNery
This seem related (Silverlight Forum: http://forums.silverlight.net/t/86106.aspx)
DominiqueBroux
Note that in your sample you don't need the layer as first parameter since it's already the main value to convert ('object value' parameter).
So you can use the ConverterParameter for your string.
PaulHuppé
Yes, that is true.  My question was more in the case where I would need to do something more complicated where I would require more information to do would be needed.
