Combine Spatial Query Sample with Query With buffer
1601
05-04-2014 03:48 PM
HushamHassan
Is it possible to combine both sample in one and adding textbox for the buffer distance.  I searched around the forum I could not find any example. I am using Sl 3.0 and C#
Many thanks
AhmedEl-Sisi
thank you,    the question is it possible to combine that sample with spatial Query sample.
of course you can, you should just break them down:
1-Draw on Map.
2-If user enters buffer value Apply buffer on drawn geometry.
3-After buffer completed Apply Spatial Filter with buffer geometry.
I attached some code for the concept.
Regards,
AhmedEl-Sisi
There is already sample for Querying using buffer.
You just need to add a textbox to get your buffer distance.
Regards,
HushamHassan
AhmedEl-Sisi
1-Draw on Map.
Regards,
HushamHassan
Ahmed
Thanks very much! That did the trick.  you provided a complete solution to my problem. 🙂
Regards
