Colorramp in arcgis wpf ???
1820
02-18-2011 08:39 AM
ThaoNguyen
I have a properties dialog that let user select a theme color and based on the theme that I generate colors which will be applied to different regions of a map.
Before, we use arcgis 9.3 api, there are ESRI.ArcGIS.Display.IEnumColors class that can generate colors for us.  Now, we are using arcgis wpf apis only, is there a similar class that achieve the same work?
Code example of what we did:
IColorRamp colorRamp = ColorRampInstance;
colorRamp.Size = 5
bool ok = true;
colorRamp.CreateRamp(out ok);
IEnumColors enumRamp = colorRamp.Colors;
IColor nextUniqueColor = enumRamp.Next();
How can we achieve the same thing using arcgis wpf apis?
Thanks!
JenniferNery
Do you mean interpolate color of graphic symbols in your map?
If yes you can refer to these samples:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#TemporalRendererPoints
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#TemporalRendererTracks
Note TemporalRenderer.SymbolAger in above samples use RampInterpolator by Opacity, this can also been done by Color. http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.RampInterp...
ThaoNguyen
Thanks for the quick response.  I think it is color interpolate but samples you gave are not quite what I'm looking for.
Each of my theme has 3 basic colors.  I pass these colors to IColorRamp.  If my map has 10 regions, I want to have 10 colors generated based on my theme applied to the regions.  IColorRamp does this for me, it will generate the colors for me.  Then, I apply these colors to my map (I know how to do this part).  I wonder if arcgis wpf provides me some color "generator" like IColorRamp or not.
ThaoNguyen
Attached is a map with different colors applied to different regions.  These colors are generated by IColorRamp based on the theme colors I pass in.  Hope this helps.
JenniferNery
ThaoNguyen
Ah I see. You can refer to this SDK sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Thematic_Interactive.
This other sample use ClassBreaksRenderer: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureLayerRendering
The first example is not quite what I'm looking for either because it uses only 1 basic color while I have 3.
I just want to know if arcgis wpf provides a quick way like arcgis desktop api does.
Thanks for your effort!
