Code for creating map labels from feature attributes
1260
09-27-2011 10:11 AM
DavidHedberg
I'm trying to find code sample that shows how to create map labels from feature attributes in a graphics layer.  I have a graphics layer with selected polygon features and their attributes.  I've developed the code for displaying the attribute information in maptips but can't figure out how to label the polygons using a textsymbol.
GarimaVyas
David,
You could follow this sample. Basically, you create a text symbol like this:
   TextSymbol textSymbol = new TextSymbol()
                    FontFamily = new System.Windows.Media.FontFamily("Arial"),
                    Foreground = new System.Windows.Media.SolidColorBrush(Colors.Black),
                    FontSize = 10,
                    Text = <bind it to the graphic's attribute>
and use it for graphics's symbol property. If you already have polygon symbol added to the existing graphics, you might have to create another graphic using the polygon graphics geometry (or its center map point).
DavidHedberg
Garima,
Thank you for the code.  This is helpful.  Would it be possible for you to also send a code snippet that shows the use of labelpoints for identifying the textsymbol placement.
Thanks.
