Clustering off/on
2256
6
07-28-2011 05:28 AM
gabrielvazquez
This seems like an simple problem, but I have to ask. I am simply trying to allow for clustering to be turned off and on for a query results graphic layer. The graphic layer has simple clustering enabled as default within the XAML.
I am providing a checkbox to allow for someone to turn the clustering off or on for the graphic layer.
I can figure out how to shut off the clustering using the simple code below, however I am not sure what would be the best way to allow for someone to turn the clustering back on.
For clusting off I am using a simple
Checkbox unchecked
GraphicsLayer layer = Map.Layers["QueryGraphicLayer"] as GraphicsLayer;
Layer.Clusterer = null
Does anyone have an example code of how they allow users to turn simple clustering back on for a layer. I was trying to use the example below, however this is for a specific custom clustering using an aggragete value field. I am simple trying to enable simple clustering.
DarinaTchountcheva
Hi Gabriel,
Here is one way to do this:
Cluster cluster;
private void Map_Loaded(object sender, RoutedEventArgs e)
            GraphicsLayer gl = Map.Layers["QueryGraphicsLayer"] as GraphicsLayer;
            //preserve the clusterer object to use it when you want to turn the clusering back on
            cluster = gl.Clusterer;
     //this is the symbol to be used for the single points that don't get clustered
            //it can be defined in your xaml, or you can difine it in code
     //if it is in your xaml you get it this way:
            SimpleRenderer simpleRenderer = LayoutRoot.Resouces["simpleRenderer"] as SimpleRenderer;
            //you can use a UniqueValueRenderer also, or not use anything
            //if you don't specify the renderer, the single points will be red circles (I think)
            gl.Renderer = simpleRenderer;
private void clusterCheckBox_Unchecked(object sender, RoutedEventArgs e)
            gl.Clusterer = null;
            UniqueValueRenderer uniqueRenderer = LayoutRoot.Resources[QueryUniqueValueRenderer"] as UniqueValueRenderer;
            gl.Renderer = uniqueRenderer;
private void clusterCheckBox_Checked(object sender, RoutedEventArgs e)
            gl.Clusterer = clusterer;
Good Luck!
Darina
P.S. Check for spelling mistakes, I just typed this in notepad.
gabrielvazquez
Darina,
Thanks again for your help. I am still having issues when it comes to the CheckBox_Checked/Unchecked.
I am recieving an error "NullReferenceException was unhandled by user code" for the
GraphicsLayer gl = Map.Layers["QueryGraphicLayer"] as GraphicsLayer;
I've isolated the code you provided and for some reason the Map object continues to come up as null. Not sure why.
DarinaTchountcheva
Accidently hit Enter and posted too soon.
DarinaTchountcheva
Gabriel,
I know I am replying a little late (it's summer time), but you can either add the checkbox handlers in code behind in Map_Loaded instead in xaml, or you can check in the Check/Uncheck event handlers if the Map object is null, and skip the code if it is.
Cluster cluster;
            clusterCheckBox.Checked += new RoutedEventHandler(clusterCheckBox_Checked);
            clusterCheckBox.Unchecked += new RoutedEventHandler(clusterCheckBox_Unchecked);
            //check first if Map is null
            if (Map == null) return;
            //check if gl is null
            if (gl == null) return;
In your xaml remove the event handlers on the checkbox:
Checked="clusterCheckBox_Checked" and Unchecked="clusterCheckBox_Unchecked".
Hope this works!
Good Luck!
gabrielvazquez
Darina,
Np on the time of your response. I appreciate your help, I consider my self a very novice coder, so your help is much appreciated. I was able to get it work. I made some minor changes to the code and where I placed it, but I was able to get it to work.
ChristopherHill
We have a sample on our sdk site that does exactly what you are trying to do.
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#CustomClusterer
