Check if graphic exist at Lat and Long
3396
08-07-2012 11:23 AM
LuisGarcia2
I have a map where I have a bunch of graphics displayed on a graphics layer. I need to add some new graphics but I don't want to add to a lat/long combination that already has one. Is there any method/function that can do this for me? If not, any suggestion on what is the most efficient way to find out this information?
Thanks!
JenniferNery
There's no method that checks if lat/lon already exist, but you can use Linq query to do that:
The following code checks if any graphic with x/y value exist. Note that the precision need to match in order for this function to return true.
   var lon = -140.9;    var lat = 63.391;    var found = l.Graphics.Any(g => g.Geometry is MapPoint && Math.Round((g.Geometry as MapPoint).X, 1) == lon     && Math.Round((g.Geometry as MapPoint).Y, 3) ==lat);
deleted-user-ATjHIWsdQYmT
Thanks!
Assuming these are points, You could loop through all of your graphics in your GraphicsLayer casting it's the geometry to a MapPoint.  take the x/y of the graphic and compare it to the one you want to add.  if it's the same then exit your loop.  Thus, not adding the point
Psudo-Code....
For each gra as Graphic in myGraphicsLayer.graphics()
if (trycast(gra,MapPoint).X = YourNewXCoord) and (trycast(gra,MapPoint).Y = YourNewYCoord) Then
exit for
end if
JenniferNery
LuisGarcia2
   var lon = -140.9;
   var lat = 63.391;
Thanks Jennifer! That works great!
