Cant get WPF Interactive API built
1017
10-11-2010 08:54 AM
MikeKaufman
Though I've built it successfully in the past, I'm currently getting a handful of "The tag/property xxx does not exist in XML namespace 'http://schemas.esri.com/arcgis/client/2009'
I've verified the references are correct.
Any suggestions?  Thanks.
MikeKaufman
I guess the WPF Interactive API hasn't been edited to run with 2.0? Is that going to happen?
dotMorten_esri
Esri Notable Contributor
Is your ESRI.ArcGIS.Client.*.dll references pointing to the v2.0 WPF versions? (ie not an older version or the Silverlight version)
