Cannot see the ArcGIS API SilverLight template after installed it in VS.NET 2010!
1157
11-21-2011 10:09 AM
AnhTruong
I am newbie to learn on ArcGIS API for SilverLight. I go to ArcGis Resource Center and download newest version. After installing it, I open the Visual Studio.NET 2010 and look in SilverLight template but could see any ESRI template as showed. Any extra setup to get esri template in SilverLight?  Thanks in advances.
DominiqueBroux
Esri Frequent Contributor
Maybe that you didn't install Expression Blend SDK.
You need the Expression Blend 4 SDK (or the full Expression Blend install) prior to installing the Silverlight API Setup to get the templates.
AnhTruong
After I installed MS Expression Blend 4 SDK for SilverLight, I got SilverLight ESRI template for C#, not VB.NET. That's good enough. Thanks for your post.
Matrix_Solutions_Inc_Geomatics
Are there any VB.net templates?
