Cannot populate XAML items in control that is contained within another control
1472
09-12-2010 08:50 AM
RyanCoodey
I have a template control Bookmark (not the one from the ESRI toolkit), and in MainWindow.xaml, this works just fine:
<sdl:Bookmark>
    <sdl:Bookmark.Bookmarks>
        <sdl:BookmarkItem Name="test" Extent="-121.89,33.60,-117.09,36.32">
        </sdl:BookmarkItem>
    </sdl:Bookmark.Bookmarks>
</sdl:Bookmark>
But, I also have a template control Titlebar which inside of its XAML contains one of these Bookmark controls, and in MainWindow.xaml, this does NOT work:
<sdl:Titlebar x:Name="Titlebar">
    <sdl:Titlebar.Bookmark>
        <sdl:Bookmark.Bookmarks> <!-- Doesn't like this -->
            </sdl:BookmarkItem>
    </sdl:Titlebar.Bookmark>
</sdl:Titlebar>
I get this error:
Error 11 The tag 'Bookmark.Bookmarks' does not exist in XML namespace 'clr-namespace:SDL.ArcGIS.Client.Toolkit;assembly=SDL.ArcGIS.Client.Toolkit'. Line 45 Position 22. C:\Projects\SDL.ArcGIS.Client.Toolkit\SDL.ArcGIS.Client.Toolkit.WPFTestApplication\MainWindow.xaml 45 22 SDL.ArcGIS.Client.Toolkit.WPFTestApplication
Bookmark does have a member property in the Titlebar class that is set to the template bookmark in OnApplyTemplate().  I tried making a dependency property for the Bookmark property too, but that didn't help either.
Is this a Known limitation?  Or most likley, what am I doing wrong?
Thanks a lot for any help!!!
*EDIT - Additional info:
Also, when doing the following, it compiles and launchs without error, but the BookmarkItems never appear in the ObservableCollection:
        <sdl:Bookmark>
                </sdl:BookmarkItem>
        </sdl:Bookmark>
</sdl:Titlebar>
Even though it compiles, this doesn't seem right to me though... having to redeclare the Bookmark.  It feels like a bookmark is being created inside a bookmark.
dotMorten_esri
Esri Notable Contributor
I'm guessing you need a collection type declared around the sdl:BoorkmarkItem (of whatever type Bookmark.Bookmarks
is). Something like (assuming the type is BookmarkItemCollection):
<sdl:BookmarkItemCollection>
<sdl:BookmarkItem Name="test" Extent="-121.89,33.60,-117.09,36.32" />
</sdl:BookmarkItemCollection>
RyanCoodey
is)
Bookmark.Bookmarks is an ObservableCollection<BookmarkItem>...
hmm, i know there are issues with ObservableCollection in xaml, not sure how to use it...  I tried making it a List too, but still not sure...
