cannot display arabic data
3619
11-20-2011 09:49 PM
SolidSmoke
Most of my shapefile's attribute table are in arabic and on the tooltips, text are displaying in different characters which cant be read...please advise me what to do to resolve this
DominiqueBroux
Esri Frequent Contributor
As in the SL API there is no out-of-the-box functionalities to display shapefiles, we would need more infos about your process:
How do you display your shapefiles? What kind of error do you run into?
SolidSmoke
I'm using Vishcious.ArcGIS.SLContrib to add graphics from shapefile using openfiledialogue. Even if I access through mapserver service, I'm facing the same issue as not displaying the arabic data.
JenniferNery
Like Dominique said, working with shapefiles may require custom code on your part.
When displaying attributes in TextBox/TextBlock, you can look up localization in Silverlight. Here are some links.
http://msdn.microsoft.com/en-us/library/cc838238%28v=vs.95%29.aspx
http://timheuer.com/blog/archive/2009/08/26/silverlight-string-localization.aspx
http://www.dotnetcurry.com/ShowArticle.aspx?ID=643
JamalNUMAN
Legendary Contributor
Hi all,
I've a problem now with the arabic font in ArcGIS 10
While ArcGIS 9.3 can read the domain of a geodatabase written in arabic, ArcGIS 10 can't!!!!!
please, see the attached screenshots
how can i solve this problem?
i need to work with my old geodatabases (that contain domains in arabic) in ArcGIS 10
thank you in advance,
regards
Jamal
Jamal Numan
DominiqueBroux
I am still not sure to understand your process, but from the screenshots you attached, your issue doesn't seem to be related to Silverlight.
It looks more like an ArcGIS Desktop or ArcGIS server issue. You may have more chance to get an answer by posting your questions on the these forums.
