Can you put a hyperlink in a maptip
2842
7
04-16-2013 10:52 AM
DonFreeman
Hi -
I would like to place a hyperlink in a maptip. I believe the coding for this would be fairly straight forward but maptips close before you can get the mouse into it. So is this possible or not and what would the code look like?
<esri:FeatureLayer.MapTip>
 <Border CornerRadius="10" BorderBrush="SaddleBrown" BorderThickness="3" Margin="0,0,15,15" Background="LightGray">
 <StackPanel Margin="7" Orientation="Vertical">
 <TextBlock Text="{Binding [SCHNAME]}" Foreground="Black"  FontWeight="Bold"/>
 <TextBlock Text="{Binding [ADDRESS]}" Foreground="Black" />
 </StackPanel>
 </Border>
</esri:FeatureLayer.MapTip>
Thanks
DominiqueBroux
Esri Frequent Contributor
Did you try to set a maptip hide delay?
(like in this sample)
DonFreeman
Thank you Dom. The sample you reference uses a GraphicsLayer. My map uses a FeatureLayer. I have tried this:
<esri:FeatureLayer ID="MonitoringSitesLayer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/AirQuality/MapServer/0"
            OutFields="*"
             Visible="true">
         <Border Style="{StaticResource MapTip_Border}" esri:FeatureLayer.MapTipHideDelay="00:00:021.5">
          <TextBlock Text="{Binding [NAME]}" Foreground="Black"  FontWeight="Bold"/>
          <StackPanel Orientation="Horizontal">
           <TextBlock Text="PM10 - " Foreground="Black" />
           <TextBlock Text="{Binding [PM10]}" Foreground="Black" />
          </StackPanel>
           <TextBlock Text="PM2.5 - " Foreground="Black" />
           <TextBlock Text="{Binding [PM2_5]}" Foreground="Black" />
          </StackPanel>
           <TextBlock Text="CO - " Foreground="Black" />
           <TextBlock Text="{Binding [CO]}" Foreground="Black" />
          </StackPanel>
           <TextBlock Text="Ozone - " Foreground="Black" />
           <TextBlock Text="{Binding [O3]}" Foreground="Black" />
          </StackPanel>
           <TextBlock Text="SO2 - " Foreground="Black" />
           <TextBlock Text="{Binding [SO2]}" Foreground="Black" />
          </StackPanel>
           <TextBlock Text="NO2 - " Foreground="Black" />
           <TextBlock Text="{Binding [NOX]}" Foreground="Black" />
          </StackPanel>
         </StackPanel>
        </Border>
      </esri:FeatureLayer>
but it doesn't seem to work. I find nothing in the code behind that look pertinent. Did I miss something? The maptip remains until I try to move into it and then closes immediately.
DominiqueBroux
As a feature layer is a kind of GraphicsLayer, that should work with FeatureLayer as well.
I don't see anything wrong in your code. Strange :confused:
DonFreeman
Thanks again Dom. Here is my map in total. Perhaps you can see what's up. The hyperlink is in the MonitoringSitesLayer.
    <esri:Map x:Name="MyMap"  Extent="748437,575771,1204687,267438" Margin="10,20,20,20" IsLogoVisible="False"  >
     <esri:Map.Layers>
      <esri:FeatureLayer ID="PimaCounty"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/AirQuality/MapServer/8" />
      <esri:ArcGISDynamicMapServiceLayer ID="PAGBaseMap"
                 Url="http://gismaps.pagnet.org/ArcGIS/rest/services/StreetsBaseMap/MapServer"
                 VisibleLayers="0,1" />
      <esri:FeatureLayer ID="AjoSO2Layer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/AirQuality/MapServer/4"
             OutFields="NAME, DESC"
             Visible="false">
        <Border Style="{StaticResource MapTip_Border}" >
          <TextBlock Text="{Binding [Name]}" Foreground="Black"  FontWeight="Bold"/>
          <TextBlock Text="{Binding [Desc]}" Foreground="Black" TextWrapping="Wrap" Width="400"/>
         </StackPanel>
        </Border>
      <esri:FeatureLayer ID="AjoPM10Layer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/AirQuality/MapServer/3"
             Visible="false">
         </StackPanel>
        </Border>
      <esri:FeatureLayer ID="AirPlanningLayer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/AirQuality/MapServer/7"
             Visible="true" >
         </StackPanel>
        </Border>
      <esri:FeatureLayer ID="TucsonCOMaintLayer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/AirQuality/MapServer/5"
             OutFields="Name, Desc"
             Visible="false">
         </StackPanel>
        </Border>
      <esri:FeatureLayer ID="RillitoPM10Layer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/AirQuality/MapServer/6"
             Visible="false">
         </StackPanel>
        </Border>
      <esri:FeatureLayer ID="SchoolsLayer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/AirQuality/MapServer/2"
             OutFields="SCHNAME, ADDRESS"
             Visible="false">
         </StackPanel>
        </Border>
      <esri:FeatureLayer ID="HospitalsLayer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/AirQuality/MapServer/1"
             OutFields="NAME, ADDRESS"
             Visible="False" >
         </StackPanel>
        </Border>
             OutFields="*"
             Visible="true" MouseLeftButtonUp="MonitorsFeatureLayer_MouseLeftButtonUp">
       <esri:FeatureLayer.MapTip >
         <Border Style="{StaticResource MapTip_Border}" esri:FeatureLayer.MapTipHideDelay="00:00:01.5">
          <TextBlock Text="__________________________________________" Foreground="Black" />
          <TextBlock Text="Pollutants that are monitored at this site" Foreground="Black" />
           <!--<TextBlock Text="PM10 - " Foreground="Black" />-->
           <TextBlock Text="{Binding [PM1]}" Foreground="Black" />
          </StackPanel>
           <!--<TextBlock Text="PM2.5 - " Foreground="Black" />-->
           <TextBlock Text="{Binding [PM2]}" Foreground="Black" />
          </StackPanel>
           <!--<TextBlock Text="CO - " Foreground="Black" />-->
          </StackPanel>
           <!--<TextBlock Text="Ozone - " Foreground="Black" />-->
          </StackPanel>
           <!--<TextBlock Text="SO2 - " Foreground="Black" />-->
          </StackPanel>
           <!--<TextBlock Text="NO2 - " Foreground="Black" />-->
          </StackPanel>
          <HyperlinkButton x:Name="myHyperLink" NavigateUri="{Binding [WebLink]}" TargetName="_blank" Content="Click here for more info." Foreground="DarkSlateBlue"/>
         </StackPanel>
        </Border>
     </esri:Map.Layers>
    </esri:Map>
DominiqueBroux
I tried your map and I didn't notice any problem (see screenshot).
[ATTACH=CONFIG]23715[/ATTACH]
As you did share your static resource 'Maptip_Border', I created one myself  (with a background in order to avoid interaction with underlying objects) and the hyperlink seems working well.
DonFreeman
Oh , sorry I missed the border style. I initially tried to send the entire page but the site rejected it because it was too large. Here is my style which also has a background.
 <Style x:Key="MapTip_Border" TargetType="Border">
    <Setter Property = "CornerRadius" Value="10" />
    <Setter Property="BorderBrush" Value="SaddleBrown"/>
    <Setter Property="BorderThickness" Value="3" />
    <Setter Property="Margin" Value="0,0,15,15" />
    <Setter Property="Background" Value="LightGray" />
   </Style>
I find that if I snap the mouse into the maptip with a very fast motion I can sometimes (1 in 10) get into it before it closes, but usually not and certainly not for the public users who will be using the map. Could there be some other settings in the page that would cause this problem? I have attached the full page to this post. Thanks
TolgaBakirman
This topic helped me a lot!
Regards,
