Can't get Graphic to show from code
1192
10-08-2010 11:06 AM
AlexAgranov
I followed the sample from
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#AddGraphics
And got it to work from XAML. Now I'm moving all that to code-behind. I've got the tiled map layer showing up, but can't get the graphic. Stepping through the code, I can see the Symbol loading properly and I'm definitely using the same coordinate as I set in the XAML but nothing shows up.
vehicle = new Graphic()
                Geometry = new MapPoint(-122.123889, 47.669444),
                Symbol = LayoutRoot.FindResource("RedMarkerSymbol") as Symbol
            GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            graphicsLayer.Graphics.Add(vehicle);
doesn't work.
dotMorten_esri
Esri Notable Contributor
Are you sure this doesn't return null?
AlexAgranov
I made the mistake of not allocating a Symbol object first. It's working now.
Faris_TawfiqAbdelFattah
Hi all
I have the same problem, i check the symbol and the geometry and thier are fine, but not graphics on the map.
Faris
