can not find feature
967
01-27-2012 01:31 PM
ForamParikh
Hello everyone,
I am trying to get graphic from feature layer in point layer i am getting graphic but in polygon layer i am not able to find that graphic.below is code.
<esri:Map x:Name="MyMap"  WrapAround="True"  Extent="-13249239.0000,3982263.0000,-13087512.0000,4087355.0000">
            <esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer"
                Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
            <esri:FeatureLayer ID="DynamicLayer" Opacity="0.01"
                Url="http://pipelineforthefuture.org/ArcGIS/rest/services/GIC4/Point/MapServer/0"
            <esri:FeatureLayer ID="polygonlayer" Opacity="0.01"
                Url="http://pipelineforthefuture.org/ArcGIS/rest/services/GIC4/Poly/MapServer/0"
            <esri:GraphicsLayer ID="glayer"></esri:GraphicsLayer>
        </esri:Map>
and on button click it is like
  private void button2_Click(object sender, RoutedEventArgs e)
            FeatureLayer featureLayer = MyMap.Layers["polygonlayer"] as FeatureLayer;
            Graphic gpoly = new Graphic();
            gpoly = featureLayer.Graphics.FirstOrDefault(gtt => (int)gtt.Attributes["LOCATION_ID"] == 395);
the polygon with 395 is available in map layer but here i am getting error object reference not set to an instance of object.
the above code is working fine for point layer as well it is working if i create feature service.but here i want to use map service.you can see from url my services are on and also if you query on 395 location_id that feature is
Please help,
Thanks
Foram
JenniferNery
Change it to:
gpoly = featureLayer.Graphics.FirstOrDefault(gtt =>gtt.Attributes["LOCATION_ID"] != null && (int)gtt.Attributes["LOCATION_ID"] == 395);
or
gpoly = featureLayer.Graphics.FirstOrDefault(gtt =>(int?)gtt.Attributes["LOCATION_ID"] == 395);
since Attribute["LOCATION_ID"] can be null, it cannot cast to int. Also if the Key is not DisplayField, you need to include it in your FeatureLayer.OutFields.
ForamParikh
Thanks it worked!!you saved my lot of time.
Thanks once again!!
