Buffer around a point with button
1385
04-03-2011 07:03 PM
SchoolRadius
Hi, I'm trying to create a buffer around a school and i only want the buffer to come out when i click a button from the pop up menu of the school, I already have the pop up menu and the map, what i need is to know how to capture the x,y coordinates of the school and how to subsequently draw a buffer around the school. Any ideas?
DominiqueBroux
Esri Frequent Contributor
If you have a popup menu of the school, it probably means that the school is a graphic. You can get the x and y  of a graphic by using the geometry:
     x = (graphic.Geometry as MapPoint).X;
     y = (graphic.Geometry as MapPoint).Y;
You can add a graphic having a Polygon geometry initialized to a circle around the school (circle to approximate by a polyline around the school).
SchoolRadius
Thanks for the pointers Dominque but i still do not really understand it fully, these are my codes for the button, there are errors when I key it in, any ideas where I went wrong or what am I missing?
protected void Buffer2Button(object sender, RoutedEventArgs e)
            GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer_Buffer"] as GraphicsLayer;
            graphicsLayer.ClearGraphics();
            e.MapPoint.SpatialReference = MyMap.SpatialReference;
            Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
                Geometry = e.MapPoint,
                Symbol = LayoutRoot.Resources["DefaultBufferSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol
            graphic.SetZIndex(1);
            graphicsLayer.Graphics.Add(graphic);
            GeometryService geometryService =
            new GeometryService ("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
            geometryService.BufferCompleted += GeometryService_BufferCompleted;
            geometryService.Failed += GeometryService_Failed;
          BufferParameters bufferParams = new BufferParameters()
              Unit = LinearUnit.Kilometer,
              BufferSpatialReference = new SpatialReference(4326),
              OutSpatialReference = MyMap.SpatialReference
          bufferParams.Features.Add(graphic);
          bufferParams.Distances.Add(2);
          geometryService.BufferAsync(bufferParams);
SchoolRadius
Also when I enter this into my codes, I keep getting an error that says "the name graphic does not exist in the current context"
string axisX = (graphic.Geometry as MapPoint).X;
string axisY = (graphic.Geometry as MapPoint).Y;
DominiqueBroux
I was supposing that you were using a GraphicsLayer or FeatureLayer to display your school.
Is it the case?
If it's the case, the graphic variable have to be initialized with the graphic of your school (either by an user interaction such as a click or by code filtering the graphics of your graphicslayer by attribute).
SchoolRadius
I am using a graphicLayer for my school and it is initialized with a button but how do I carry on and draw a buffer?
p.s. sorry I'm quite lost, I'm new to this
